brake booster
jivemother33
lisbon ohio
i think i got a problem..with the car idleing in park, i step on brakes the engine speeds up like the booster is leaking vacume, any one got any ideas...??
i would say its leaking since it is directly related to you pressing the brakes. You can try to run it, turn off the engine and listen closely for any leaks. If you are lucky it might just be the check valve, if not, its the booster gone south.
Which is why im converting to manual brakes on my b'cuda...:D
also i have the vac line hooked to the carb insted of intake, kinda temperary could that be the cause ?
