Brake caliper interchange??
funhntt
Active Member
I need to know what the year and make of what cars I can get a set of front calipers to fit a 74 duster? Just need the cores. Thanks if anyone can help.
I'm very interested to know for sure as well because I thought all the 'slider' single cyl calipers were all the same for a, b, f, m, j and r (not c) also for either 11 or 11.75 disks (as the only diference is the slider adapter). I dont know anything about the pin type calipers though.
According to Hollander interchange, the '73-5 A-body and '74 B-body with the slider type calipers are the same. Many other calipers will work if you include the caliper bracket.
Just know that the 76 and newer has a slightly bigger piston then the 73-75 models.
