VonCramp
Does anyone know of a 10" rear drum with a larger 2 3/4" opening at axle?
2.83...
Now I can use aftermarket axles! I matched it up with a Roadrunner drum.
I already have larger pattern. I have to buy a new drum to match the axle that I am buying to replace the one that got cut down by the differential builder. The axle I found has the larger flange (2.75) as opposed to 2.25. The drum I bought though is wrong. It is too wide at the shoes. Any ideas what I should look for? Later Duster maybe?Those would be big bolt pattern. Is that what you are going with?
