67ragtop
Converted my 67 barracuda over to disc brake fronts using a 1976 Duster. Still running drum in the rear. Everything is brand new, Lines, Master Cylinder except the brake equalizer mounted on the frame rail. I did not bleed the master cylinder because I thought I wouldn't have to because there is no fluid in the whole system and it's new. I put fluid in for the first time and got pedal after a few pumps. Bled the driver side and no fluid and the pedal would not hit the floor. Pumped the pedal a few more times and got fluid in the passenger side. We pumped the brakes several times and tried to bleed every other wheel with no fluid and no decrease in pedal. Turn the car on and no brake light except when you hit the emergency brake. What did I do wrong? I even cracked both lines off master cylinder and drained some fluid. Still have a hard pedal and no luck at any other wheels. Fluid is up in master cyclinder after a refill.
