jelybean
I have a dodge 600. The calipers started to stick and i installed new calipers. the brake pedal goes almost all the way down to the floor and then snaps/pops all the way down. so i ended up changinging the master cylinder. installed it and checked it w/ the plugs in before connecting the lines. the pedal was solid. i reconnected the lines and it goes all the way to the floor still. i dont see any leaks under the car from a blown brake line but wondering if it is the calipers i got are bad, or if it is possibly the proportioning valve. if i go to move it it does not stop. i checked the rear brake cylinders and they are both dry. i think on payday, or even tomorrow i am gonna rig her calipers from her dodge on the car and see if thera is a pedal. be my luck that the calipers are bad. anyboy have any suggestions??? I have had them bled several times and still have the same problem. i'm going out to get a Proportioning Valve for it today and see if that will fix the problem. have no brakes they just drop to the floor and nothing. I didn't bench bleed the mastercylinder someone ese did. jim thinks it's the calipers and won't work on it anymore. After installing the Proportioning Valve it still does the same thing, and I want to bleed the brake again everyone thinks it would be a waits of time and doesn't want to do them again.. I'm think about just getting rid of the car. don't want to since I only payed $200 for it. help anyone
