65cuda360
I did some looking and can't read the casting #s on my spindles. From the research I did it looks like the 72-71 b&e inner bearing is 1 1/4 bore and the 73-76 a&e is 1 3/8 bore. Is this correct? If my spindles are 73-76 A spindles can I use later F body caliper adapters and calipers? Is that going to put me in a bind looking for odd brake hoses? I'd rather put slider type calipers and the bigger 11 3/4 rotors if I can. Bolt pattern is not an issue at this point.Rather go bbp if I can.
