brake pedal won't return
rudyscuda
rudyscuda
alaska
68 barracuda with master power 4 disc brake conversion, all the info I've seen there is no spring on the pedal but it will not return, anyone have an idea?:read2:
You may have a blown rear wheel cylinder or a leak in your brake line.Has fluid in the master cylinder gone down?
Thats my guess. Happened to us in Nikkis 66 dart at a red lite. We were waiting for the lite to change and the peddle went to the floor and didn't come back up. I feathered the e-brake into a parking lot, got it towed home, checked the fluid and it was low, looked at the inside of the rear wheels and the pass side was soaked. I threw in a new wheel cylinder, washed down everything with brake kleen and all was well.
