Looks like I can get Autolite 3926 which is just hotter that 3924
That carb is just for the run stand to get the motor broken in and leaks fixed. I have the Holley super sniper efi and hyper spark ignition and coil ready to go but I do not have the fuel pump for that setup yet
Okay understood and thanks, it was a head scratcher until you threw the idle speed and vacuum numbers out. Definitely have a vacuum leak. But at any rate when you get the coolant temperature up to 190-195 degrees, that spark plug should be hot enough. It's just not reaching self cleaning temperature in that aluminum head. Are you checking the upper hose temp with the temp gun? Get your coolant temperature up into and your tune-up set up right and the plugs should burn off. When adding fuel and oxidizer, you usually need a step or two colder on the plugs to prevent detonation. I definitely would not go hotter, that plug is equivalent to an RC12Y champion.
512 rb 175 compression in the non burnt cylinder. Carb. 750 holley. torker 2 manifold....
I never have and do not have the ability to do so. If it does not run well on the stand I will change the torker2 to something else before going into the car. Hopefully fixing the vacuum leak will help as well as new thermostat to get the coolant up. I never mentioned that the radiator is a giant 29 inch griffin. I have squeezed it into the engine bay of the 73 scamp but not with the engine in place.Ever flowed a torquer 2 , a lot of variance from runner to runner . I got one down to 25 cfm diff. , and I`m no expert .
We got it to idle at 800rpm smoothly, only 12.5in hg vacuum at that. Idled smoothly and revved nicely. Still have an oil leak that we will tackle next.
