Foxxwoof
Member
I've been lurking for quite a while, but I spent some time digging through my build sheet today and I figured I'd post it up. There are still a few things I haven't figured out yet.
Line 1
??????? - SEQUENCE NUMBER
626 = June 26, 1970
295183 = ORDER NUMBER
L = DODGE DART
M = MEDIUM TRIM GRADE
23 = 2 DOOR HARDTOP
H = 340 4-BBL
0 = 1970 MODEL YEAR
R = BUILT IN WINDSOR CANADA
32XXXX = VIN SEQUENCE NUMBER
Y05 = BUILT TO U.S. SPEC'S
Line 2
ENGINE - 55 = 340 4-BBL (assumed)
TRANSMISSION = 32 = A-727 (assumed)
AXLE - 53 = 3.23 RATIO
S/G - 1 = SURE GRIP
TIRES - T76 = e70 x 14 rwl fiber
TRIM CODE - D2-X9 = Deluxe 50/50 bench seat - vinyl, black
UDF - TX9 = black, Upper Door Frame color
PAINT STYLE - V01 = monotone paint
BODY PAINT - FJ5 = Sublime Green
ROOF PAINT - FJ5 = Sublime Green
V21 - Performance Hood Black Out
LINE 3
STEERING COLUMN - ??? = ???
STEERING COLUMN - X9 = BLACK
STEERING COLUMN - 1000 = Manual Steering Collumn
STEERING WHEEL - 18 = ???
STEERING WHEEL - X9 = BLACK
HORN PAD - 71 - ???
HORN PAD - X9 = BLACK
RADIATOR - 78 = 2998978 22"
INLET HOSE - 92 = 2863292 W/340 ENG
ALT - 72 = 3438172 (STAMPED) SINGLE GROOVE 37 AMP
FAN - 15 = 2863215 18" 7 blade w/340 (clutch type)
FAN SPACER - 33 = FLUID/THERMAL DRIVE UNIT 2863233 (FAN CLUTCH)
BATTERY - 51 = P#3755151 - 48 AMP GROUP 24 W/GREEN CAPS
STRIPES - V8W = Transverse Bumblebee Stripe (White)
LINE 4
VAC FIT - ?? = ???
ENGINE - ?33 = ???
CARB - 69 = PN 3462 969 Carter 4-bbl AVS, ID number 4934S (340-Auto)
TRANS - 769 = #3410769 A727 Auto Trans w/ 340 4
PINION - 33 = #2538933 Speedometer Pinion with 33 Teeth YELLOW
PROP SHAFT - 693 = ???
AXLE - 019 = ???
WHEEL - 51 = 14" small bolt pattern Rallye???
COLOR - TX9 = BLACK
SPARE - 12 = 14"x5.5" P# 2660312???
WHEEL COVER - 24 = Trim Ring P#2944424
FRAME - 64 = ???
S/BAR - 39 = ???
SHOCK FT - 54 = 3400854
SHOCK RR - 94 = 3400594
FRONT BRAKES - 19 = K/H Disc Brake car
LINE 5
TORSION BAR LT - 893 = #2535893 DIAMETER .870, 120 LB/IN SPRING RATE
TORSION BAR RT - 892 = #2535892 DIAMETER .870, 120 LB/IN SPRING RATE
REAR SPRINGS LT - 081 = ???
REAR SPRINGS RT - 081 = ???
BRAKE PEDAL - 17 = Automatic Trans Brake Pedal #2950878
CLUTCH PEDAL - 00 = no clutch pedal
LABELS IDLE - 07 = #3577707 Emission Decal
LABELS TIRE - 56 = ???
EXHAUST LT - 40 = ???
EXHAUST RT - 41 = ???
TAIL PIPE LT - 70 = ???
TAIL PIPE RT - 71 = ???
CAR HEIGHT - AM1 = Low Car Height???
1 - 15 = ???
3 - 11 = Broadcast sequence from 00-99
LINE 6
A62 = RALLYE INSTRUMENT CLUSTER PACKAGE
B41 - Front Disc Brakes/Rear Drum Brakes
C23 = REAR ARMRESTS W/ASHTRAY
C93 = CARPET
LINE 7
POLICE ENGINE - F01 = ??
ALTER - F17 = ??
RADIO SUPP. PKG. = F17 (4) - ???
BATTERY - F22 = ???
_______ - F22 = ???
SPOTLIGHT LT - F31 = ???
SPOTLIGHT RT - F32 = ???
ROOF LIGHT REINF - F38 (0) = None???
And my fender tag:
*END *
N41 N42 R11 V21 V8W YO5
FJ5 G33 J45 M26 M43
FJ5 D2X9 TX9 626 295183
E55 D32 LM23 H0R 32XXXX
LINE 1:
E55 -340 1-4bbl 275 HP 8cyl Engine
D32 -A-727 3 speed automatic transmission
LM -Dodge Dart/Medium Price Class
23 -2 door hardtop
H -340 1-4bbl 275 HP 8cyl Engine
O -Model Year/1970
R -Assembly Plant/Windsor, Ontario Canada
32XXXX -Sequence Number
LINE 2:
FJ5 -Body Paint Color/Sublime Green
D -Trim Grade/Deluxe
2 -Trim Style/Vinyl Bench Seats
X9 -Trim Color/Black
TX9 -Upper Door Frame Color/Black
626 -Schedualed Production Date/Friday June 26, 1970
295183 -Vehicle Order Number
LINE3:
FJ5 -Roof Paint Color/Sublime Green
G33 -Left Outside Chorme Remote Mirror
J45 -Hood Pins
M26 -Wheel Lip Moldings
M43 -Grille Surround Moldings/3 Pieces of Chrome
LINE4:
N41 -Dual Exhaust
N42 -Chrome Exhaust Tips
R11 -AM Radio/Musicmaster
V21 -Performance Hood Treatment
V8W -Sport Stripe Transverse/Tape - White
YO5 -Built to Specifications for/U.S. Order
END -End of Sales Codes
Anyway, just thought I'd share. If anybody sees anything wrong feel free to point it out. Line 3-5 were hard to find most of the info on. Especially the wheels "51", I found a reference to that on an E-body forum being Rallyes.
Also I'm pretty sure I read that the Fleet codes on line 7 on a car from Windsor, basically don't mean much of anything. Is that right?
Line 1
626 = June 26, 1970
L = DODGE DART
23 = 2 DOOR HARDTOP
H = 340 4-BBL
0 = 1970 MODEL YEAR
Line 2
S/G - 1 = SURE GRIP
LINE 3
HORN PAD - 71 - ???
LINE 4
VAC FIT - ?? = ???
ENGINE - ?33 = ???
AXLE - 019 = ???
COLOR - TX9 = BLACK
FRAME - 64 = ???
S/BAR - 39 = ???
LINE 5
1 - 15 = ???
LINE 6
C93 = CARPET
LINE 7
ALTER - F17 = ??
BATTERY - F22 = ???
_______ - F22 = ???
And my fender tag:
*END *
FJ5 G33 J45 M26 M43
LINE 1:
23 -2 door hardtop
O -Model Year/1970
LINE 2:
LINE3:
J45 -Hood Pins
LINE4:
N41 -Dual Exhaust
