Broken antena
perko
Seaside, California
Hello,
I think some drunk stumbled into my car or something but the piece that attaches to the locking ring is snapped off. Does anyone know of a good way to replace this? I'm not even sure what the part is called to try and google it.
Looks like you need the white metal part. Your two plated pieces look reusable. The wire unplugs from the base of the antena unit and the mast also unscrews. If you were closer I would give you one.
You only would need the housing itself . Not the wire lead or the mast. I have them here apart if you would like pictures. You shouldn't need the whole assembly and I have extra parts .
I gave 8 masts to the grandkids for toasting marshmallows. so I have extra parts.
You MAY be able to access the under side of the antenna from an open door
If not you will need to remove the splash guard to the rear of the wheel opening under the car. If there is undercoating finding the screws can be challenging.
Look at ones for sale to get an idea where they are located
lmao, I think you'd have to straighten your antenna if it were a drunk. Antenna mast bezel.
