63dartman
Looks like I need a new pushrod....This is what happens when you accidentally put the pushrod against the block verses the lifter and torque it down. My engine has been running like this for a month. It has been a little noisy so I decided look at the pushrod preload and found this. When I first put the magnum heads on I noticed one of the lifters was not moving so I just loosened it up and put the pushrod back in the lifter bore without thinking what damage had been done.
