Build sheet decoding
matt030305
Baldwin, NY
could someone help me decode my build sheet? Really hard to find info without the proper knowledge. Thanks
It would help to see a proper scan of it. The photo is barely high enough resolution to read, as well as being distorted.
Take 2 pictures with half of the sheet on each photo. And take the photo straight on. Not at an angle.
Many of the numbers are the end of a part number like if you have 891 + 892 in the torsion bar section you can go to the proper year parts book and look up torsion bars and look for your car type and the last 3 of the part number. Then the description tells you what it's called.
There are other numbers which represent packages, and you can look in the sales books available on sites like mymopar.com or The 1970 Hamtramck Registry Home Page
Not too many options......it's a 1971 Slant 6 Duster, 225 engine, 904 transmission, 2.76 rear, A/C, tinted glass, 50 amp alternator, AM radio, power steering, woodgrain steering wheel, bench seat. That's about all I can read.
