fishy68
Tyr Fryr's Inc.
Good choice on the cam. Had it in my 360, nice power and lopey idle. Later swapped it for the compcam XE 274. Hate to say it but Old School MP cam ran as good as the New school compcam.....had lifter problems, so went back to old school MP solid cam and haven't looked back... minimum 650 carb..........
Bob
Are you sure your talking about the same Mopar cam? I ask because the one he listed is not a solid cam, like you said you went back to. Comp did have some lifter problems 2-3 yrs. ago. I also used a XE274 in a 360 and had 2 sets of lifters go bad right off the bat. First set only lasted about 150 miles and the second set only lasted about 500 miles before they wouldn't pump up after sitting over night. I heard their USA lifter supplier was on strike and they bought lifters from China and the tolerance was crap. Don't know if it was true but it made sense. They've got it straightened out now.
BTW: The comp XE274 isn't any more aggressive than an old school MP cam so as long as you don't need more exhaust duration the Comp probably won't make more power. Comp's HL series are a little more aggressive. About = to the Lunati Voodoo's.
