gen2hemi
former ASE knuckle buster
- Joined
- Mar 15, 2010
- Messages
- 63
- Reaction score
- 1
This is a running-in-the-car transmission setup for my hemi (650 ft-lb) that I am pulling to do an overdrive trans. It has approx 1200 miles and no racing on it since a complete rebuild by Pat Blaise (Tflite Patty)
This is a very solid 727 for a high torque motor and street performance. To go racing or for a small block you will want a different converter.
I will palletize and crate and no charge, or will deliver free in Seattle-Portland corridor.
$1500 + shipping
Inquire PM or bpieser@msn.com
- Blueprinted Hemi 864 converter (8 bolt crank) with needle thrust bearing and brazed fins - stalls 2800 against my motor
- 6 disc front drum
- Bolt in overrunning clutch (sprag)
- All new metals and HP friction material
- TCI Cheetah 71-up style standard pattern valve body with part throttle downshift
- TCI monster cast aluminum deep pan (+3 qt)
- Detailed sand cast case painted Eastwood Alumablast
- All receipts
$1500 + shipping
