Bump stops, lower control arm. Best? No squeak.
MOA
CA
The front suspension is going together, whether it likes it or not.
Any recommendations that worked? The top bump stops are there and in the right spot, I don't think I'm gonna get airborne that much, I think we're good here.
One sweet jump has nothing to do with the upper bump stops, at least not more than once.
What are you asking for or what are you stating?
Lower control arm bump stops.
Not being rude But what are info are you looking for? Your question is more of a statement. I’d like to help but can’t figure out what you are asking for about lower control arm bump stops. Single nut hold them on place.
No offense I'm a bit confused too... the way bump stops work they don't really squeak like bushings do, no sliding/rubbing going on just "bumping" lol.
I could actually use some different ones for my Duster I have lowered the front end a bit and cut the factory bump stops down but they're still too tall, interested in others' suggestions as well...
@72bluNblu I think you've touched on this before?
If your bumping off the stops... no pun intended- then you are too low to begin with. Sounds like you need lowered front spindles so the geometry stays proper but the car goes lower.
i know they sell spindles that are made to lower the car like 2”.
Not necessarily, if the torsion bars have been upgraded then the wheel travel will be much less than stock so the bump stops can be shorter. Drop spindles on these cars don't actually work as well as lowering the whole suspension system and retuning it for lower ride height and stiffer springs, modern alignment for modern tires etc.
I was just looking to see what others have used and been happy with.
Anyone know of 1 1/4" bumps tops for the lower ??/single 3/8'bolt--------------
I used these cut to length. I actually wanted mine slightly taller to keep my oil pan off the ground in case of wheel stand.
