Bussmann CBF-20 Does anyone here use these in their A Bodies
69FBCuda
Stand back 10' for your viewing pleasure & Safety
Florida
Aside from determining what caused the fuse to blow in the 1st place.
Can definitely save some back breaking fuse replacement especially when the old blown fuse refuses to come out. Only drawback I can see is if it didn't trip correctly it could get costly.
Bussmann CBF-20 Circuit Breaker (Type II, Glass Fuse Style Automotive - 20 A), 1 Pack
  • CBF Series, Type II, Glass Fuse Style Automotive Circuit Breakers match the 1/4" x 1-1/4" glass fuse footprint
  • For use in glass tube fuse blocks
  • 20 Amp, 32 Vdc
  • Modified Reset Design - stays tripped as long as there is power to the circuit - reset by turning off the circuit, or by turning off the ignition switch
  • Meets SAE J553 standards; sold individually
  • Fit type: Universal Fit
https://www.amazon.com/dp/B00139FQLU/?tag=fabo03-20
Standard fuses have been working fine for 100 years, if you have a blown fuse issue you better fix it rather than band aid it.
As for Bussmann EOL was 2018 so were riding on existing inventory
While I agree with that statement, it did not answer the posters question. I’d like to know as well.
