More stall is not always better. Think of stall in the lines of when you release a clutch the full way. It also makes more heat, and if you cruise at all it will always be slipping. Creating heat and more problems my friend, stay within your recommended stall range, 2-2500.
This may help:
http://www.badasscars.com/index.cfm/page/ptype=product/product_id=78/prd78.htm 'What does a high stall converter do?'
Last paragraph:
Most street performance cars running your typical "performance" cam should be running a stall converter in the 2,800 RPM area. For hotter cars (street / strip) with bigger cams, etc. then a converter in the 3,000 - 3,200 RPM is more suited. For mild performance cars with something like a 350 HP engine, a 2,400 stall is about right. The basic rule of thumb is; if your engine "comes alive" at say, 3,500 RPM, then you want a stall converter with about 3,500 of stall to it. Most people tend to over cam and over carburete their cars... and those same people tend to under stall converter their cars too, which REALLY makes it a complete turd. if they need a 3,000 RPM stall, they'll usually get something like a 2,000 RPM, which just doesn't get it off the line. You have to remember... 80% of the race is the first 100 feet. If you can't get off the line, you are going to lose the race.
