[WANTED] Cable end
383Scampman
New Hampshire
Seeking speedo cable end . The part that screws onto the adapter . Mine is missing and since I am not using a speedometer all I need is the end so the fluid won't trickle out . This would be a great help . thank you . I live in 03276
The seal inside the holder around the speedo gear is what is supposed to keep fluid in, not the end nut.
If you don't use it pull the gear out if it has one and shoot a good shot of silicone in the hole where the gear went.
Done. :D
