vntned
Working on a motor swap in my ‘77D100. I bought a 360 that was ran a few times in a circle track car. The motor was cheated a bit but is fairly mild. Specs are as is:
‘70 360 block 0.020” over
4027169 crank shaft
44109XXX connecting rods (can’t quite make out the whole number)
Speedo H405 pistons (I need to measure how far in the hole they are)
J-heads cut 0.050” with 2.02/1.60 valves
‘73 340 intake milled for the heads and center divider modified
*I need to math out what my actual SCR
This motor is gonna be going in my ‘77D100 2wd. The truck weighs 3700lb. A727 trans. 3.23 gear in an 8.75. And 28” tall tires in the back. The truck is not a daily driver but it gets driven all the time. It is NOT a race truck, but I do want some more power and fun over the current setup. The only things I’m looking to change on my setup is the cam and converter. I want to keep my 3.23 gears, and I am not gonna go crazy and change heads or pistons. I’m just trying to pick a cam and converter that will optimize what I’ve got already.
4027169 crank shaft
