Cam and timing set install question
dropped it to what?
you have the same setup almost as my cam you close @57 iam 60
iam 10 to 1 169 psi dcr 8.21
@57 close id be 174.30 dcr 8.4 i would haved liked that
I have the same setup as you except I'm at 4500ft, what's my pressure?
thought you have a stroked biggy 600 hp
iam just a lil hi miles 340
I was hoping you would do the math before AJ does. lol
The only small block I have is a 360 in the 73 W200, an that sucker pings at 5000ft.
@69GT
To answer your question in a simple manner. If everything was machined correctly (cam/timing set), you line it up using the 0 dots. That should get you the 4* advance.
It's best to verify the install.
Back to your regularly schedule program of "War and Peace" answering of questions. :)
dropped it to what?
IIRC, they brought it down to around 9.3 or so. Puts me in the 7.8 DCR range.
@69GT
:rofl:
