robert87ss
Member
hi guys, I'm building my first big block. this is only the second time ive ever installed cam bearings. I used the proper tool and seen it done many times. however this is my first big block. I was told to use the old cam to "square" the bearings because big block mopars are notorious for having cam bearing alignment issues. i find this very hard to believe that i would need to hit the old cam with a hammer to "square" the bearings. also was told its normal for the cam to be tight! i have never ever done this before on any engine ive ever built. also the new cam supplied with the kit has a larger base circle, does this mean i will need shorter push rods? note this is a bone stock rebuild.
