B3422w5
It will be mighty mild on a stroker motor.
Strokers eat up lots of duration.
The cam on my 360( its just over 10 to 1) is 260@50 on a 106. Its gnarly, but settles right in at 1100 rpm
Your a little wider so the idle wont be as choppy on the 108.
Should make good power. I would have went probably 6 or 8 degrees bigger, but my cam is probably 6 degrees too big( but was on a shelf and close and i needed it in a hurry) for a stock stroke.
Should make good torque for ya. Its very easy on a 4 inch motor to have something even around 260ish and have it ultra managable and streetable
Good luck!
Good luck!
