Cam ID
sireland67
WV
Hey guys,
Picked up a 340 that had been built a few years back and never started.
Tore it down just to check everything.
72 .030 over bore
.010 main and rod
Pistons KB 243 with SL 97 stamped on the other side.
974 head which look like they have had extensive porting.
The question I have is with the cam, I can not identify it.
It has 1136 stamped on the timing chain side.
27 and at 180 degress H7 stamped on the distributor side.
There is also an 02 stamped at the distrbutor end.
Can you guys help me with the cam?
Found a number on the end of the cam 182620.
Also I measured the lobes with a caliper, 1.240 base and 1.575 which if my math is correct comes out to a .502 lift.
It looks like it may be a crane version of the .508 / 292 that they use to grind for mopar purple cams.
This cam is not purple.
