[WANTED] Cam needed
Anyone have a good new
RV/TOWING camshaft for 318 or LA engine ???
Thanks Chris
I need to squeeze a little more power out of this 318 !!
Summit Racing® Classic Cam and Lifter Kits SUM-K6900
Use this one put it in 4deg advanced should help out that heavy truck. at 117$ with lifters cant get cheaper.
put 360 J heads, helps out big time !!!
Just a bolt on , easy conversion . good 4 bar. Intake mani. helps also. Little things thats make more power without major work. Been there, done that ! Many times over the years.
Thank you info
I cant wait to tear into it after Christmas !!!
I need Maximum torque !!!
