As I get closer to starting this engine for the first time (for me) I wonder how this cam is going to act. I got the engine with the car 7 years ago and promptly lost the cam card so this is completely off of memory, so I apologize in advance, but I wonder what you guys think. I called the engine assembler/builder in the early years of ownership and remember him telling me that he remembers doing a fairly stock setup on this motor ie cast pistons with around a 9:5:1 compression ratio. This is a 383 B motor. I can get the casting #s off the heads tonight if it makes a big difference. This is the cam.
CHRYSLER COMP Cams 21-248-4 COMP Cams Magnum Solid Camshafts | Summit Racing
Thanks FABO!
Thanks FABO!
