Well i was just asking about a timing issue in a previous thread, and i typically go by the thought process that anything worth doing..... is worth overdoing
With that said, if i wind up tearing into my slant 6 which im presuming is a 225 to go after a timing issue, i might as well shell out for a cam and lifters, if im going to shell out for cam and lifters, im sure as hell not going back with another stock one...... with that said, is there a cam out there that would give a good kick in the *** to a slant 6 without head work and changing compression?
I see fleabay has a comp cams 260H kit with valve springs and all, but 260??? smooth idle? seems so tame. According to the spec sheet, it seems like it would be a great mid range cam offering a decent boost in power. i thought mopar was the only ones still making a cam for this engine..... who knew.
if i do it, id complete it by going with a header and probably a 500cfm holley, possibly smaller, 500 so big to such a little engine.....
would i gain enough power by doing this to make it worth the investment?
