[WANTED] cam s/b
moparraceman
mansfield ohio
looking for new cam and lifters for 340 would like hyd maybe the 284 - 484 mopar or something into the low 500 lift reply threw conversation ,with description ,picture and price thanks
What is the intended purpose of the car?
Any requirements on cam characteristics?
Gear ratio and tire size, what trans and stall if applicable?
What is the RPM range on said cam?
I have a really gnarly old Crane grind. It's hydraulic flat tappet and new in the box. I cannot remember the specs off the top of my head.....I will have to dig it out and get the cam card. But it's a little over .500 lift and is ground on a 106LSA so it will sound nasty. If you're interested, I will find the cam card.
Comp is having problems with their lifters . bad set ordered through Summit. had 4 that would sink and long time to pump up . Stood behind them but no labor paid out. I swear by solids . You know that they are all working the same for a balanced air charge. Hyd are a guessing game
I have a new hyd Comp Cam that I believe is close to the Purple Shaft cam specs you mentioned above. I'll see if I can locate it. Feel free to PM me.
Check out Delta cam
Great prices . Talk to Jon
