[SOLD] Cams, oil filter adapter, throttle bracket, thermostat housing.
V8-valiant
Central Oregon
All parts are located in Redmond Oregon.
Used Comp hydraulic flat tappet cam with lifters 500 miles. $150
Used Comp mechanical cam (no lifters) 1500 miles. $100
Used Bullet hydraulic flat tappet cam with lifters & springs 300 miles $175
90 degree oil filter adapter with new bolt & gaskets $95
Small block cam parts lot $45
8 new NGK R5671A-8 spark plugs $15
8 new NGK BKR6E spark plugs $15
New Spal electric fan wiring & relay kit (missing temp sender) $35
Used Canton billet oil filter plate $45
Used Jegs carburetor throttle bracket $45
Used Billet specialties -20AN thermostat housing $45
