Camshaft Keyway direction
RattleCanStan67
Washington State
Rebuilding a 340 and do not have the pictures i took when pulling apart the motor. I have the camshaft keyway and it is offset on one side and indented in the other slightly. Need to know what is the correct way to put this in my new cam please and thank you
Stick it in any direction and degree the cam. That’s the ONLY way to know.
One way will be advanced, one way will be retarded. I would be best to check the centerline of the cam with a degree wheel. But I can tell you that all the cams that I checked, I have not retarded the cam to get the recommended or required position.
