L lenweiler Well-Known Member Joined Jan 29, 2005 Messages 765 Reaction score 4 Location Canada Oct 2, 2015 #1 Anyone running high 9's on the engine. What's your camshaft profile? Assuming it's a roller.
roccodart440 Well-Known Member Joined Apr 19, 2010 Messages 6,800 Reaction score 3,578 Oct 2, 2015 #2 I'd be indebted to you if you tried this cam. Crane Cams #688681 Lift:0.675 int./0.638 exh Duration at 050 inch Lift: 280 int./288 exh. 114 LSA
L lenweiler Well-Known Member Joined Jan 29, 2005 Messages 765 Reaction score 4 Location Canada Oct 2, 2015 #3 Little shy on the lift, but duration @ .050 looks close to what I think I need.
440dartsport Well-Known Member Joined Oct 14, 2010 Messages 607 Reaction score 145 Location Kewaskum, WI Oct 2, 2015 #4 How many cubic inches and what compression.
L lenweiler Well-Known Member Joined Jan 29, 2005 Messages 765 Reaction score 4 Location Canada Oct 2, 2015 #5 420 cu.'s and 13:1 cr. Heads flow 345 cfm.
roccodart440 Well-Known Member Joined Apr 19, 2010 Messages 6,800 Reaction score 3,578 Oct 2, 2015 #6 Damn, that's what my new heads flow and your going 10.30's.. Kind of exited right now.
L lenweiler Well-Known Member Joined Jan 29, 2005 Messages 765 Reaction score 4 Location Canada Oct 2, 2015 #7 this is a new combo. Old combo were w5's.
D-50394 Well-Known Member Joined Jun 21, 2013 Messages 515 Reaction score 120 Location Alabama Oct 2, 2015 #8 I run 6.20's in the 1/8. The Wallace Racing calculator says my best is 9.82 in the 1/4. My solid roller cam is a custom and is 255/266 @ .050 , 10.9 comp. at 2950 lbs. Pump gas 394 cubic inch.
