dibbons
Just found photos of a recently sold 3854S AFB on Ebay which is pictured with the choke pull-off valve (choke vacuum diaphragm) connected to the port I use for distributor vacuum advance which is on the front of the carb right alongside the passenger side idle mixture screw.
My 3854S AFB pull-off valve is currently connected to a port on the passenger side of the carb near the front which is directly below the pull-off valve (which you can see in the photo is free/open). On page 14-58 of my Plymouth 1965 Service Technical Manual we find it showing my hose arrangement is correct. Just be careful when you purchase stuff online.
