It can be fixed but you will need someone who knows how to weld cast.. And if I remember correctly you would have to take the tranny apart just to change the tail shaft as the rear bearing is mounted in the tail shaft, just can't remember if it has a clip that has to be removed or not, been awhile since I have worked on one.
