Can you guys help me figure out my Compression ratio
not in my opinion as long as the engine is properly tuned for that temp and you use high quality oil.
i should add that on the few nitrous engines i built, i ran them a little cooler and put slightly cool spark plugs in them to reduce the potential for detonation . i also ran high voltage ignitions with minimal plug gaps like around .026" to .028".
i should also add that i am far from a nitrous expert, however, what i do is similar to what other people i know that run nitrous do and it works for my apps.
By all means thanks for the feedback. What band and how cold of a plug did you run.
