ratty dart 340
Hello everyone, I recently finished some college finals and have been hard at work on my dart. I had the heads machined, just installed them with felpro 1008 head gaskets. And torqued the head bolts to 95 lb/ft. I then installed my rpm airgap intake and made sure rtv the water ports and everything from there has been very smooth.
Today I went for the first start, and got it to a point of good idle and sounded good. However, there was a coolant leak , leaking onto the starter, and I am unable to find the source. My first thought was the header bolt and a water jacket. I tightened the bolt in question(closest to firewall) and it still seems to be leaking. Small drops every 10 seconds. I don’t think it’s coming from the head.
Next, there seems to be a similar thing on the passenger side, however it seems wet between the head and block, but maybe that’s just the way the coolant traveled.
Now for the sketchy part. I did this same job a couple months back and ended up with coolant mixing with my oil via a head gasket. I had torqued the head bolts down the un-torqued them. I learned this mistake. I drained the oil which was complete milkshake. So this time around I made sure to only tighten the head gaskets one time in three increments to 95 ft lbs.
I had the car idling today and it sounding very good. Open headers though so I could only hear so much. However, I pulled the oil dipstick and it’s white… it seems to have mixed the coolant again somehow.
However, looking at the valvetrain, it seems to be just oil. With maybe a small amount of coolant( can’t quite tell)
My question is… is it possible some residual milkshake was left from last time, and that’s getting moved through the engine, or is something still wrong with the head gasket/intake.
