I have a slant 6 225.
Again I’m having more trouble with the ignition(mopar electronic). Everything is new except for the pickup on the distributor. So new ballast, ecu, regulator, coil, cap and rotor.
Now Saturday I went to start the car and nothing but crank. No spark out of the coil. So I switched the coil with a working one I had laying around. Now the car will start and then immediately sure he itself up to about 3k rpm, then die. Very quickly. Could it be the distributor pickup going bad. Remember this is electronic ignition.
