RichB
CherryCuda65
I have a few infusion pumps (3ml) with small dia. tubing that can be used to pull the fuel out of your carburetor bowls without taking the carb apart. If your carburetor has a vent tube to the bowl like a Carter AFB, you can put the tubing right down the vent tube and pull out the gas from each bowl before letting your car sit for the winter. Then you can pump gas back in with it and immediately start the car.
Many other uses like lubricating hard to get at spots.
$5 ea. + $2 mailing. PM me with your mailing address. Pay with Paypal.
