Carb help!
nuttyprof
York, Nebraska
I have an 80 Volare /6 1bbl. The carb is a Holley 1945 with all the emission ports, and the bolt holes for securing the top to the rest are stripped and wallowed out (that way when I got the car). The car runs poorly and many of the vacuum lines are cracked or hooked up wrong. I do not have to pass inspections, so I want to remove as much of the garbage as I can and replace the carb with one without all the extra vacuum ports. Does anyone have a spare 1bbl carter that will hook onto the throttle and kick down cables that they would be willing to part with? This car will be a daily driver for no more than 2 years then it will donate disc brakes to my 62 Valiant so I'm not looking to spend a lot for a super carb. Thanks all.
I have a Holley you can have for the postage. It's off a 1972, worked fine when I pulled the engine. I had rebuilt it a couple of months before that. Been sitting outside for a few months, though.
