Carb Install
LJS30
Hemet, California
I just purchased a T-Quad and now need to install. I have installed a carb before but I've always had leaks of some sort occur. Any tips, pics, hints, etc...would be helpful. Thanks guys.
make sure you use the gasket between carb and manifold
if i had any i would tell you
if you use studs you can insure it is tight instead of bottomed out on the bolts
other than that thats all i got
sorry
Well I installed the carb, primed it, started right up, and sounded oh so sweet. The throttle was a bit high so I made a slight adjustment then, car sounded great, then suddenly I have a miss. What do you guys think? Fouled plug?
