g413
Recently I took my car out and it stalled several times in the first two minutes. The picture shows the carb with a cold engine. Notice the choke valve is wide open. Shouldn't it be closed? I pressed on the valve to close it but it would just barely move about 1/4". The hang up is the linkage that goes down to the well-type choke (thermostat?).
My 67 Barracuda at some time had a 318 put in, but the Carter carb is probably original. Of course the I.D. tag is missing. So my theory is the little thermostat is frozen and won't allow the valve to shut. Does this sound correct?
I know these thermostats are not serviceable, but can you identify the carburetor and where can I get another one of these well-type choke thermostats?
Normally how long does it take for the choke valve to open up after starting the car?
