JoesEdge
Lately, I've been taking some time to understand how a Holley works while driving. I've done some tuning to my Holley and I've seen improvement, but I had noticed that I had some enrichment (or lack thereof) problems.
In order to see what was going on with my engine as I drove, I plugged an Actron vacuum gauge to the manifold vacuum port on the base plate of the Holley.
First, is that the correct location to plug in the vacuum gauge?
I do not have any other source of vacuum on the engine that I can plug into, other than the capped off port on the metering block, but as far as I understand, that's the "ported" vacuum port.
Anyway, when fully warmed up my engine idles at 15 to 16 in/Hg. When I cruise (let's say at 2,000 RPMs steadily or even 3,000 RPM's steadily), I'm usually around a solid 22 in/Hg. Back off the throttle and the vacuum may jump up as much as to 26 in/Hg.
If I step on the throttle to accelerate and pass someone (not excessive speed), I can see the gauge go down to maybe 18 in/Hg. If I step on it hard and I have the pedal to the floor (I need a buddy to verify that it's really WOT), I do not see the gauge drop too far below 10 in/Hg. It's solidly at around 9.5 in/Hg to 10 in/Hg.
What I'm getting at is... I don't think my power valve ever opens. It's a 6.5 power valve that was recommended. To me, this explains why I do not see my WOT (or what I believe at this point to be WOT until I can verify) enriching; therefore, running leaner than I'd like at WOT.
This might also explain why the Edelbrock I tried was always too lean too. If the metering rods never raise, then it will not move into the power mode to add fuel to the in coming air.
Anyway... The largest Holley power valve is a 10.5 which I can try. But I'm wondering if my 750 is too small. I have read that the vacuum at WOT should be close to 0 in/Hg, and that anything more is a sign of the carb being too small. The next step up would be an 850 cfm carb, but would an 850 be too much for the street?
I guess I'm trying to get an understand how engine vacuum and carburetors work together. I'm hoping someone could explain it better so I can understand it further.
Much appreciated for any help and understanding.
