iggys68dart
i ran out of gas last week and picked up some water in carb so while cleaning carb i went with rebuild kit replaced gaskets power valve accelerator pump and check valves reset both floats [ holley 4160 600cfm carb] now i have what is best described as a flat spot i idle motor up to 2g rpm and it fluctuates like it is bogging down a bit i have improved power but there is a half second or so hesitation when i take off i sprayed carb cleaner around carb looking for leaks. no luck, any guesses, i know its hard to guess and not hear it but all advice will be cosidered including let someone else fix it lol
