66Dvert
Working on my custom car parts again!
I have this nice "bling bling" manifold getting ready to go on to my /6.
but I want to find some thicker gaskets that will space up the carbs so I can connect the PVC hose to both and then to the valve cover (or just one and block the other but I still need 2 gaskets to keep the carb height the same.
Has anyone got a part number for a 1/4 inch thick gasket?
Right now the linkage is in the way just a bit. The hose would rub in it and I don't want that. you can see how close it is in the pic's. the front carb is the problem since it hits on the locking collar for the linkage the back one clears just.
I might be able to go 3/8th (change studs for sure) but I don't think I can go much higher unless I change studs and then I gotta worry bout hitting the hood (maybe not since I'm using stock breathers with a dropped base) but I have not measured yet. don't even have the engine done yet but I'm trying to cover all bases.
thanks
thanks
