Hello all,
looking for some input regarding the electric assist portion of a Holley 2bbl model 2245's carburetor choke thermostat heaters "eclectic assist" function.
My sons 360 Power Wagon is equipped with this choke. Currently there is no power hooked up to the element, but I see some sort of porcelain electrical device (ballast(?) on the intake manifold that is not being energized during the run ignition position (no wires feeding the device are present).
The truck doesn't like to start with the choke butterfly fully closed. If we open the butterfly 1/8" she fires well and warms right up and the choke butterfly returns to a non restricted position when the engine achieves operating temperature.
I see no adjustment for the choke butterfly other than "tweaking" the actuating rod, is this correct?
