Carburetor health checkup
skep419
5.9 Magnum 4 speed afficionado
Minesoooota
How often are you guys taking your perfectly good running carbs apart? I drive my car quite a bit, recently cleaned my dad's Edelbrock and it was full of crap (he barely drives it). It got me thinking I should be tearing the Holley down once a year just to check it out?
I've had my brawler 750 going for about a year on 10% ethanol premium. I've driven it prob 3,000 miles, it feels like it's brand new, I have no plans to tear it down personally.
If the car is being driven fairly regularly like once a week or every two weeks, at least I would think there’s no reason to disassemble the carb. The fuel will be flowing through and being refreshed and not breaking down in the bowls from sitting and evaporation.
I was about to ask a similar question, so lets see how this goes!
I have a Holley Ultra 750 DP on my 340. Had it on there about 9 years now (had to check, longer than I thought!), the car is driven regularly most of the year. I've replaced the bowl and metering block gaskets a few times, seems like that was more a result of taking the bowls on and off when I was tuning the carb. I recall having to change the accelerator pump diaphragm at one point because of a leak, think that was a few years ago. Little over a year ago I had a rich at idle condition just show up, which I finally tracked down to the needle and seat and/or the o-ring on the primary float. Had to change the gaskets as soon as I touched the float adjustment, those gaskets immediately failed when I loosened the lock screw.
Fast forward to this year and I had the same issue return, now the secondary needle and seat/o-ring. I probably should have replaced just the o-ring just to see if that fixed it by itself or if the whole assembly was allowing the leak. Really I should have changed them both when I figured out the primary needle and seat was an issue!
Obviously 8-9 years on a needle and seat assembly is plenty! But I was also curious if non-racers had an interval for changing gaskets/seals/o-rings in the carbs. For racers I would assume that the more frequent tuning would already lead to more frequent gasket and seal changes.
If it's running good, I don't take it apart.
That's definitely been my line of thinking, although with a couple of issues cropping up I'm beginning to think a more wholesale replacement of the gaskets/seals/o-rings might be in order at this point. Just curious if anyone else has a schedule for that or if everyone just deals with things as they fail.
Lucas fuel treatment every couple tank loads works wonders.
Grandpa swore by STP fuel treatment, if it had the logo he used it, I think he worked with Petty. lol
If your tank has rust/junk in it I’d pop the top/pull the bowls at least once a year. If it’s a fresh clean fuel system I’m with @RustyRatRod if it ain’t broke, don’t fix it.
