alwaysamopar
Ok first off I have used the search function with no luck I am trying to change from a 2:45 to a 3:21 ratio I am running out of adjusting room before i can get gear backlash correct So I know I need another carrier So whats the cut off? I have one from a 2:71 ratio Will this carrier work for the 3:21 gears? Oh yeah this is a open carrier i am talkin about Found info only for sure grips Thanks for info in advance!!!!
