amusingarts
Hi guys,
I'm putting a Carter AFB 4299S on my 273 Valiant convertible. I upgraded from a 2bbl manifold to a Edelbrock LD4B high rise manifold. Alas, I'm lacking the bits that will connect the cable and the kick-down rod to the carb, I'm also missing the bracket that hold down the throttle cable. These parts, unfortunately, all stayed with my long gone 2 bbl manifold and carburetor.
I'd appreciate any help or advice on this. I believe the big issue is stock part compatibility with the high rise and downshift rod length. Maybe lokar is the way to go?
It seems the piece I'm looking for will attach both the rod and the cable, so it has to have the ball for the rod ( I have the downshift rods) to fit on, and a connection for the cable.
Thanks in advance.
A. Musing
Thanks in advance.
A. Musing
