Tof
Hi all ,
After the rebuild of my 318ci i buy a news carburator , on this carb' i use the oem choke ( thermal spring with fast idle cam) .
For use my Dart every day the thermal spring is not good ...... really is some **** .
i make this system for use the rpm in manual , the choke is always connected on the thermal spring but the fast idle cam now is under my control .
After one mount the deal is excellent , this "redneckHomemade" compensates the bug with the choke thermal spring of some carter bbd ......... not really the best carb for the performance but the best for drive every day with the Sp98 at 8$ the gallon ..........
