[FOR SALE] Cast Crank 440 Short Block
mrmopar66
Seymour, IN
Rating - 0%
0   0   0
Mid 70's cast crank 440 Block, Crank, Pistons, Rods, Rod Bearings, Rings.
Engine will need main bearings and then assembled. Has some slight surface rust that a scotch brite would remove. Block has been professionally cleaned, honed, and new freeze plugs and cam bearings installed. Block is a standard bore and the crank is .010/.010. Pistons are new and the rods have been reconditioned.
Please look over pics and I have more on request. Like I say the rust on it is minor
and it is due to drawing moisture in my garage.
$500.00 OBO
