If I change my tie rod ends to Cbody which are a bigger thread and also change out the sleeves to fit them, will I be able to re-use my center link and have them just drop in or do I also need a center link. I thought the only difference was actually the size of the threaded end which goes into the adjuster sleeve which should also be a cbody part?
