Robbie2734
Lambcharger
I have a two part question, what year 318 piston had the largest compression height and do they all share the same wieght?
The second question is the same but for a 360. I know there was some different heights and I have a ton of good oarts for the two motors and want to put together one or both with stock pistons to save on balancing. The motor will be for street use and will be a mild build.
